vcBitmap
Represents an image file used in the application, for example as material textures.
Referenced by: vcMaterial.Texture, vcPythonProcessHandler.Icon
FormatvcBitmapFormatRGets the format of the bitmap.
HeightIntegerRGets the height (in pixels) of the bitmap.
NameStringRWGets or sets the name of the bitmap.
UriStringRGets the URI of the source file of the bitmap.
WidthIntegerRGets the width (in pixels) of the bitmap.
loadBitmapvcBitmapString argLoads a bitmap image from a given URI.
If loading is successful, the URI filename is used to register the bitmap with the application.
uri (str): The URI of the bitmap.
RuntimeError: When the bitmap cannot be loaded.
vcBitmap: The bitmap.
saveNoneString uri,
Optional Keyword[format = vcBitmapFileFormat]
Saves the bitmap to the given URI.
uri (str): The destination URI.
Optional: format (vcBitmapFileFormat): The destination format. Default is vcBitmapFileFormat.BMP.
ValueError: When the vcBitmapFileFormat cannot be mapped to a writer module.
RuntimeError: When no writer module is found for the given file format.
RuntimeError: When the bitmap cannot be saved.
